Nuno137
DSP48E1 logic functions
Hello, I have a very simple question. There is no info about this simple thing in the documentation. I can't test this with my board so that's why I ask you.
I need to use a DSP48 to implement a 48bit wide boolean function, like an AND or a XOR. Usually the AND of N bits is just the product of all boolean variables, so it is zero if at least one variable is zero, and one if all variables are one.
In the DSP48 I assume this is not the case, considering the output is still a 48 bit wide signal, and it is not a 1 bit signal. The AND of these 48 bit input signals, X AND Z, is the 2bit AND of the corresponding bits? For example assuming the signals are 6 bits wide:
010110
AND
110101
010100
Is this right? Does the DSP actually do this?
bruce_karaffa
Your assumption is correct, the DSP can perform bitwise logic operations.  I believe that you must explicitly instantiate the DSP and control the mux and operation registers to utilize this feature.
@Nuno137
The DSP48 is used to do many things as described in the following document.
https://www.xilinx.com/support/documentation/ip_documentation/dsp_macro/v1_0/pg323-dsp-macro.pdf
However, the DSP48 is not used for boolean operations.
When you use boolean operations in your HDL, they will be implemented using circuit blocks in the FPGA called Look Up Tables (LUTs).
Cheers, Mark
Nuno137
I don't understand why.
In this guide: https://www.xilinx.com/support/documentation/user_guides/ug479_7Series_DSP48E1.pdf
In "Embedded Functions/Two-Input Logic Unit" it says that I can perform also basic functions. There is also a list of possibile functions. I want to use this, and I'm not interested in the multiplication/addition capabilities of the DSP48. In the list there is for example the function "X XOR Z" or "X AND NOTZ". What I want to know is what these actually do.
I know it is not intended as so, and DSP48 should be used for things like FFT or audio processing, filters and so on, but I may need to save resources and so I may be interested in using the DSPs.
bruce_karaffa
Nuno137
Thank you, so you mean that I have to manually tweak all the signals in order to utilize the dsp in this way?
Thanks both for the replies, much appreciated!
