Akhil1400
DUC/DDC compiler run time B.W. configuration
Hi All, As of now I am using DUC/DDC compiler for 20Mhz B.W., but I want to make this IP for all b.w. is there any procedure through which we can configure in run time? Thanks in advance.
vkanchan
Hi @Akhil1400 ,
DUC/DDC IP can be customized for only one LTE bandwidth configuration at a time.
There is no facility to reprogram the Bandwidth configuration at run time.
