krunal_h_bhavsar
Delta Sigma ADC given in sysgen demos
         I am trying to implement Delta Sigma ADC into spartan 3E starter kit but it not working........DAC is working properly......I have tried with delta sigma ADC demo given in the sysgen........In simulation it working properly but when I generate bitstream to implement it into FPGA with defining fpga's I/Os its not working........If any one have any idea about it please help me..........
Thank you in advance...........
idiotic_genius
CAn you send me your DAC code? I need to implement DAC in spartan 3e.
Regards, abhidan@logictronix.com
Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos if you think it was helpful and reply oriented.
zengqh
hello ,CAn you send me your DAC code? I need to implement DAC in spartan 3e.
dpaul24
@krunal_h_bhavsar,
If you want to get proper help here, you must specify in particular what is not working. You have to mention what you done to come to the conclusion that "it" is not working.
Put screenshots, RTL, block-diagrams for better illustration.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
bruce_karaffa
@krunal_h_bhavsar  @zengqh Not to mention that responding to an 11 year old post is not likely to produce any results.  Start a new post and as @dpaul24  mentioned, include enough detail for someone to understand your problem.
dpaul24
@bruce_karaffa,
Thanks for that note on the date! If I would have seen that earlier (OP date), I would't even have cared to reply. :-D
zengqh
ok
fernandovives
I'M trying to use the ADC and the DAC present in the Spartan 3e kit. Can you share your DAC code? Thanks in advance.
