Doubt in connecting clock port of Black Box while connecting it to Microblaze via FSL bus
Hi  There :-)
I had imported a verilog file which consisted of synchronous logic to System Generator as a black box.
My verilog code is as follows:-
                             /*  customlogic.v  */
module  customlogic(
output  reg  [31:0] sum,
input    wire  [31:0] a,
input    wire  [31:0]b,
input    wire            clk,ce
always @ (posedge clk)
begin
  sum <=  a + b;
end
endmodule
In the EDK processor  token I changed my bus connections from PLB to FSL.
When I tried to connect it to the Microblaze through the FSL link but the ports  'clk'  and 'ce'  which  would be synchronized
automatically if I connected it to a PLB bus is now left open.
Should I connect it to "sys_clk_s" that exists in the dropdown list in ports window?
And which port should I connect my FSL_CLK, FSL_FIFO_R_CLK, FSL_FIFO_W_CLK to?
The version of tools I am using are Xilinx ISE 10.1, XPS 10.1,System Generator 10.1
The board I am using is Virtex 2 Pro (XC2VP30-7FF896).
Thank you and regards,
anand
ticktack
Firstly you need to take a look at Black Box HDL Requirements and Restrictions (page 328 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_1/sysgen_user.pdf)
Then take a look Export as Pcore to EDK section(page 389)
Hi ticktack :-)
I guess I have followed all the rules required to connect the black box . The simulation is working fine.
The clock is connected to a default SPLB clock when I connect my peripheral to the PLB bus of the Microblaze processor.
However when I connect it to the FSL bus of Microblaze to my custom peripheral the clock port is being shown in the Ports
window of XPS and I do not know which port to connect it to.
Should I configure it in System Generator to connect it to the default FSL bus clk  or should it be configured in XPS?
Should I use some DCM etc?
I keenly await a response.
Thank you :-)
ticktack
I think EDK project will use DCM. I'm not familar at the Embedded side. Normally you should be able to see clock ports in MHS. I guess sys_clk is used.
Thank you :-)
I shall check it out :-)
