ECC in BRAM for FIR Compiler, DDS Compiler IP
Is it possible to enable ECC for any BRAM instantiated in IP such as the DDS Compiler and FIR Compiler?
回复: ECC in BRAM for FIR Compiler, DDS Compiler IP
No, it's impossible as you have no control of Bram inside FIR and DDS IP, also the ECC can only be abled on some data widths.
