ERROR:coreutil - XST has returned an error: coreutil:1012 - Command ERROR:sim - Error found during generation. ERROR:sim - Failed to generate 'FIR_I'. XST has returned an error: coreutil:1012 - Co
I have installed same version of ISE that is ISE 14.3 on two PC both have windows 7, 64-bits Professional. On one PC i have installed ISE one month ago and on another PC I installed it ten days ago. Now I want to generate the FIR Compiler 5.0 core with distributed architecture. so on in pc on which I installed ISE earlier it gives no error. but on another PC it gives the above subject error. Any help in this case.
thansk
Re: ERROR:coreutil - XST has returned an error: coreutil:1012 - Command ERROR:sim - Error found during generation. ERROR:sim - Failed to generate 'FIR_I'. XST has returned an error: coreutil:1012
The root cause of the issue is bad installation . Please reinstall the ISE and see if you can resolved the issue. Make sure antivirus running on your machine disable during installation
Thanks and Regards
Balkrishan
This is not the installation problem. I reinstalled the whole system I mean reinstall the window first and then reinstall the Xilinx ISE 14.3 but the same problem occurrs.
are you getting this error specfic to this IP or all other IP . I would recommend you to use ISE 14.7 version
You may use Vivado design tool if you are targeting for  7 series and latest response
Thanks and Regards
Balkrishan
This problem is for this specific IP core and specific for FIR Compiler 5.0
This was reported by several customer and actually issue solved with tool migration or re installation
Thanks and Regards
Balkrishan
Newbie hanyanzhe
hello,I found a strange thing.It will be error if you build ip core by named capital letters.but it will be right if you build ip core by named small letters.you can try!
I would recommend you to use latest version of ISE 14.7 or Vivado 2017.2 . The old versions are not supported yet
Thanks and Regards
Balkrishan
