Error 0001: Internal Error Block: 'DSP48CoProcessor/Processor Subsystem/EDK Processor/proc'
HI,I do a experiment of  co-simulation,when I generator the block of hardware co-simulation,the fllowing error happens,I really don't how to solve this error; the error log is as follows:
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 10.1.1134 D:/Xilinx/10.1/DSP_Tools/common/bin/../../sysgen
AccelDSP 10.1.1134 D:/Xilinx/10.1/DSP_Tools/common/bin/../../AccelDSP
Matlab 7.5.0.342 (R2007b) D:/Program Files/MATLAB/R2007b
ISE 10.1.i D:/Xilinx/10.1/ISE
Summary of Errors:
Error 0001:
Reported by:
Details:
An internal error occurred in the Xilinx Blockset Library.
Please report this error to Xilinx ( http://support.xilinx.com),
in as much detail as possible. You may also find immediate help
in the Answers Database and other online resources at http://support.xilinx.com.
Error occurred during "Block Configuration".
Re: Error 0001: Internal Error Block: 'DSP48CoProcessor/Processor Subsystem/EDK Processor/proc'
I would try reinstalling the tools.
Then make sure you clear you cache.  There is information in the SysGen User Guide no how to do this.
Also try replacing the SysGen token with a new one from the library.
Chris
Video Design Hub | Embedded SW Support
