Error: An error occurred when creating the Vivado project... Block: Unspecified
I am taking the sysgen tutorials and following ug948-vivado-sysgen-tutorial.pdf . I am not able to generate to compile the design into hardware.
Summary of Errors:
Error 0001: ERROR: An error occurred when creating the Vivado project...
Block: Unspecified
Error 0001:
Reported by:
Unspecified
Details:
error copying "{C:/Users/Namrata
Kogalur/Desktop/mitacs/project/ug948-design-files/SysGen_Tutorial/Lab1/netlist/sysgen/lab1_1_clock.xdc}":
no such file or directory
INFO: [Common 17-206] Exiting Vivado at Fri Jun 10 11:28:07 2016..
I have attached my model.
are you getting this error with all the designs are specific to current design . This can be installation issue is all designs failing with same error
Thanks and Regards
Balkrishan
Hello Namrata,
I had the same problem. The issue is this: In your file path, there is a space in "Namrata Kogalur". Xilinx does not like path/file names with spaces. Move the project to a different directory without spaces in the name. Your design will then be able to find the correct XDC file. Good luck!
Aditya
Error has been resolved by deselecting the option "Post-synthesis" in the system generator token in the compilation tab.
i couldnt find post-synthesis in my system generator token in the compilation tab.
can you show it by sending an image?
thanks
