Error Message Using the Xilinx IP Core Error 0001
I receive this error from my memory block, if I want to use the CORDIC IP core as a black box. If I use the another Cordic block from the simulink library everything is fine. To simulate the IP core I use the ISE simulator. Does anyone know this error.
Thanks for help
#--------------------------------- Version Log ----------------------------------
Version                                 Path
System Generator 11.4.2254              /net/sw/xilinx/11.4/DSP_Tools/lin64/sysgen
AccelDSP 11.4.2254                      /net/sw/xilinx/11.4/DSP_Tools/lin64/AccelDSP
Matlab 7.7.0.471 (R2008b)               /net/sw/matlab/2008b
ISE 11.4.i                              /net/sw/xilinx/11.4/ISE
Summary of Errors:
Error 0001: Indeterminate condition enncountered for the IF statement...
     Block: 'MIMO_awgn_fading_fft_ifft_Cordic_coded_win/SIC/QR Decomposer/QR Decomposition/Sorting and Memory/Subsystem/Dual Port RAM Imag Odd1'
Error 0001:
Reported by:
  'MIMO_awgn_fading_fft_ifft_Cordic_coded_win/SIC/QR Decomposer/QR Decomposition/Sorting and Memory/Subsystem/Dual Port RAM Imag Odd1' (XILINX dual port memory)
Details:
Indeterminate condition enncountered for the IF statement at line
128:13 which contains array method.
Error occurred during "Simulation Update State".
Everything is OK if you use a different version of the CORDIC or a different one with different settings?
Everything is ok if I use the CORDIC from the Simulink System Generator library with the same settings instead of the generated CORDIC IP Core.
