Visitor active92
Error XST 2587
I am a newbie using blackbox. This is my first time. When I run this using System Generator, it was fine but when I try it using ISE, it gives me error. I've attached the codings below.  Can anyone please help to see where is the error?
Re: Error XST 2587
How are you importing Sysgen Black box design into ISE, what type of compilation?
Can you post the full error log, snapshot of your design and more details of tool versions
But it looks like a common error,  check relavent posts
http://www.xilinx.com/support/answers/31998.htm
http://www.xilinx.com/support/answers/23283.htm
Hope this helps
Vanitha
Re: Error XST 2587
Hope this helps
Vanitha
Visitor active92
Re: Error XST 2587
Below attached the error and the simulink.
Re: Error XST 2587
It looks like your Scaling Accumulator block inputs are not matching the data type or other definitions of your _config.m file; Please go through earlier post links and try the AR suggestions.
I think you have to try with std logic vector or other types instead of integer in your .VHDL file, based on your Bitbasher, Lut ADDR dat types.
Also check is the sample types are matching for the blocks.
Visitor jigarmori
Re: Error XST 2587
Hi, I am also looking for these files and other files.
filter_lut_b.vhd, lut_adder.vhd, scaling_accumulator.vhd and others.
Can you please mail to jigarmori@gmail.com
Jigar Mori
