Visitor kevin5k
Error message: Unknown Container Type
I am designing a simple system to perform simple arithmetic calculations, of which requires division and I have used the Cordic divider to achieve this. No error is detected during the initial design simulation compilation. The problem lies when I close matlab and re-open the same mdl file and re-run simulation.The persistent error message for the cordic divider and is as follows:
Error reported by S-function 'sysgen' in 'lu_lower_triangular_matrixv1_2_2/CORDIC DIVIDER/Quadrant Correct/Mult1':
Error: Unknown container type
The error highlighted is related to the mult block, within the quadrant correct sub-system in the Cordic Divider blockset.
Question is, what am i doing wrong? Or is this a bug?
Re: Error message: Unknown Container Type
Have you tried the following:
1) Clear your Sysgen Caches,
>> xlcache("clearall")
2) Ensure you are opening Sysgen from the Start menu.
3) Create a TEMP environment variable pointing to C:\temp
If this doesn't help and If you havent already done so, perhaps you should open a webcase to have this investigated.
A few things mentioned in the AR below are worth checking.
http://www.xilinx.com/support/answers/44617.htm
@kevin5k wrote:
Cheers,
Jim
