Error with System generator
I have never used Systgem Generator.
ISE/DSP tools 11.4 and Matlab 2009b on Ubuntu 9.10 x86_64.
I'm just trying to do a simple execution of the sample programs, when I try to generate a bitstream (or anything else for HW generation) I get the following error:
 This is a simple copy of the lab2.mdl from the examples in system generator
<snip>  p, li { white-space: pre-wrap; }
standard exception: XNetlistEngine:
An exception was raised:
com.xilinx.sysgen.netlist.NetlistInternal: couldn't open first pass text file at /store/home/rob/src/fpga/SystemGeneratorExamples/lab2/netlist/sysgen/masterScript3952952072241003825.pl line 477
</snip>
Reported by:
Unspecified
Visitor dang2327
Re: Error with System generator
The problem in this case is because of the script "saferun" in System Generator binary folder. This script governs the execution of Xilinx Coregen to create the necessary cores for your project. However, there are two "export" lines in "saferun" that could not be executed by the OS somehow.
Thus, modify the "saferun" script in your XILINX System Generator installation folder at /opt/Xilinx/11.1/DSP_Tools/lin64/sysgen/bin/saferun:
    - Replace
                     'export LD_LIBRARY_PATH=$dir'
       with
                    'LD_LIBRARY_PATH=$dir
                     export LD_LIBRARY_PATH'
    - Do this for every occurence of 'export' statement
My "saferun" script now looks like this:
dhn24@Danh-ubuntu:/opt/Xilinx/11.1/DSP_Tools/lin64/sysgen/bin$ cat saferun
#!/bin/sh
# This wrapper sets the LD_LIBRARY_PATH environment before running the
# associated executable.
prependldpath() {
    dir=`readlink -f $1`
    if [ "$LD_LIBRARY_PATH" == "" ] ; then
    else
        LD_LIBRARY_PATH=$dir:$LD_LIBRARY_PATH
    fi
binpath=`dirname $0`
libpath=$binpath/../lib
if [ -e $libpath ] ; then
    prependldpath $libpath;
fi
prependldpath $binpath
# Now run the executable
cmd=`readlink -f $0`
$cmd.bin "$@"
-- This should solve all the internal errors of System Generator and generate your hardware model.
Hope this helps,
Danh.
Visitor dang2327
    - Replace
       with
#!/bin/sh
prependldpath() {
    else
    fi
fi
$cmd.bin "$@"
Hope this helps,
Danh.
Visitor dang2327
Actually, I retested this solution, and found that unless you comment out EVERYTHING in the "saferun" script but the last two lines, the problem will persist.
So, here is my updated "saferun" script:
$cmd.bin "$@"
... and all problems are solved.
Danh.
Newbie nexaya
Thanks dang2327, commenting all lines except those 2 did the trick !
