aravinda
Errors occurred during netlist generation. Error reported by S-function 'sysgen
I get the above error repeatedly when I try to run Hw-simulation or create an IPCore. This happens for the files that have no problem with simulation and those files for which I could create IP cores previously.
I use system generator 2016.b. Something has happened after I came from summer vacation.
Wasting a lot of time now by restarting the computer etc.
Truly appreciate your words of support.
Aravinda
Truly appreciate if someone could help
aravinda
Solved it by myself.
Method:
Delete the netlist folder and hwsim folder in the respective directory. Restart SysGen. You will see the problem solved.
Reason:
There must be a netlist corruption that spoils the SysGen environment. Not verified reason though!
Note:
There could be some cases where hwsim model does not get created but ipcore gets generated.
Cheers!
