FFT 7.1 error
  I am using Matlab 2009b, simulink platform ans xilinx blockset.
  I need to use FFT 7.1 for my design and I met some problems during the simulation that I don't understand
  I've added a screenshot of the simulation and the problem occured.
  Waiting for your assistance
Arik Tomer
The error message is pretty clear: you have undriven inputs (highlighted in red) on the FFT core. If you don't plan to use those inputs, connect them to appropiate constants. The blog below has a SysGen FFT example which you can take a look:
http://myfpgablog.blogspot.com/2010/07/fft-results-from-matlab-fft-bit.html
@d04110 wrote:
Arik Tomer
Cheers,
Jim
But it's connected to a constant..... you can see in the picture
The FFT core shown in your picture has 7 input ports and you only connected 3. All input ports need to be driven. The undriven ones are highlighted in red like this > (xn_im for example).
Cheers,
Jim
It doesn't help...
We tried to drive every input with every constant and even tried the recommended solution (placed the parts exactly like in the picture)
here is another screen shot of the situation - I don't know what to do here
It did help as now you're getting a different error message. I suggest you keep reading the error message until you understand what it means and then think about what needs to be done to fix it. You may need to go over some of the SysGen tutorials with simpler examples (check the link below) so you can understand how SysGen and fixed point works before tackling a bigger project.
http://forums.xilinx.com/t5/DSP-Tools/Available-System-Generator-Documentation/td-p/52551
@d04110 wrote:
It doesn't help...
Cheers,
Jim
