Anonymous
Not applicable
FFT(9.0) output magnitude threshold
Hello!
I am trying to implement a FFT magnitude estimation system. I am using a DDS compiler which outputs a sine wave into the FFT block. After the FFT the regular formula : Mag= sqrt( Re^2 + Im^2) is added. Basically what I want to achieve is to detect is if the output of the FFT is over a certain magnitude. I don't really understand the FFT output or what I am doing wrong.
 Should I not be getting a single spike where the inputted sine wave of 10MHz is added?
What am I missing here?
Thank you in advance!
Anonymous
Not applicable
Pictures in higher res:
bwiec
I would start by validating FFT output data to make sure your core configuration/interfacing is correct and then debug your custom logic.
So can you split fft_data_out into real and imaginary parts and plot it to make sure it looks reasonable?
www.xilinx.com
