FFT C model download
HI everyone,
I can't seem to find the c model for the FFT core at this link http://www.xilinx.com/products/intellectual-property/fft.html
Can anyone guide me on how to download the c model? as I am trying to simulate it in matlab.
Thank You
Re: FFT C model download
everytime i login my xilinx account and go back to the FFT ip core it seem to indicate i am not login therefore i cant download the c model
The latest cmodel is no longer delivered through that lounge. Instead, when you generate the IP in Vivado, it will place the cmodel in your target directory.
www.xilinx.com
what about the old version? like ver4 and ver5 as I still have need them some of my design using virtex 4 and 5.
   I am using the FFT core in ISE 13.2 and 14.7. In both cases there is no C model generated. Please guide if the c model has to be downloaded or is it generated by some other means.
I'm looking into this. Stay tuned.
www.xilinx.com
   Looking forward to your response. We need the models to simulate our system.
Anonymous
Not applicable
I also require older FFT C models (specifically the 6.0 and 7.0 cores). Any news on how to obtain them?
Moving to correct board.
Debraj
you can download here http://www.xilinx.com/products/intellectual-property/fft.html
under the related products tab
I am using ISE 14.7 Webpack.  I cannot find the C model anywhere.  Argh... why does this have to be so hard.  Where can I find it.
Matt
Anonymous
Not applicable
@berkeraliisik wrote:
the C model doesn't seem to be there anymore. Is it still available anywhere?
hello
Is the fft core c-model still downloaded from
https://www.xilinx.com/products/intellectual-property/fft.html
I couldn't find the link to this model. Thanks.
Note: even I login, there's no place for this.
XFFT v5.0 CModel attached
Thanks and Regards
Balkrishan
thanks a lot!
@poorren pelase mark the post as accepted solution
Thanks and Regards
Balkrishan
how do I mark this post as accepted solution? Sorry for delay.
you just need to click on Accept solution!
Thanks and Regards
Balkrishan
Sorry, I couldn't find this button. Where's that?
See attachment for what I could see.
You can try logging off and login again . I think it should work
Thanks and Regards
Balkrishan
Hi Balkrishan,
I tried again, still couldn't find that. Sorry.
The current, and I assume final, version of the FTT for ISE is version 8.0 for AXI and version 7.1 for not AXI. The c model code needs to be available on this website somewhere. There are many links instructing the users how to load this source code that simply do not work.It would be great if you could post a working link for both of these sources here. Xilinx simply cannot ignore this problem. Vivado does not support all the °active° parts, so this does matter.
So it appears this request is just going to be silently ignored by Xilinx. No "We aren't going to do that", no "Here is the data you requested". Not a good look, but unfortunately not a total surprise.
Any hope that we can get a response to this request?
