Raghunath
FFT IP core hanging after sometime
Hi, we have used fft ip in our design initial for some sample the fft is worki fine.
after some time fft is not giving any output or requesting any data what may be the wrong.
my configurations: 32 point fft.
joancab
Advisor
Advisor
Is it the FFT itself or the DMA you may use to feed data to it?
Raghunath
RFADC ip core output directly feed the data to FFT ip
joancab
Advisor
Advisor
Have you tried with an ILA? Is there a chance of it hanging because of NaN results?
dgisselq
@Raghunath ,
There are a couple of reasons why the FFT IP core might hang: 1) Violating the AXI stream protocol, 2) Holding M_AXIS_TREADY low, and 3) Not setting TLAST at the end of an FFT.  This last might happen if you lose count of values going in and out of the FFT
Dan
Raghunath
thanks its the axi interface problem the issue resolved now
