Visitor vivekv
FFT configuration Xilinx core v 8.0 (not a power of 2)
I am planning to use the the FFT core for a project and would like to know how the core should be configured if I am not using a power of 2 FFT. e.g. I want to calculate a 800 point FFT using a 1024-point FFT core. How should this be done?
Do I pad the additional 224 data points as zero to get a 800 point FFT using the Xilinx core?
Thanks in advance !
Re: FFT configuration Xilinx core v 8.0 (not a power of 2)
Have a look at the below link
http://forums.xilinx.com/t5/DSP-Tools/FFT-N-points-no-power-of-2/td-p/60598
Satish
xilinx FFT core only support pow 2 FFT. you can try mixed radix FFT for your custom FFT points
Thanks and Regards
Balkrishan
