amki
FFT in sys gen
hi . please help me to Troubleshooting this error and connect the data in "from file " to  "FFT" in sys gen.
thanks a lot.
pthakare
Hi @amki
When you load data from file , Use Gateway In block between data from file to input to the FFT block
i.e
im_s -> Gateway in ->data_tdata_xn_im
re_s -> Gateway in -> data_tdata_xn_re.
Reply when you have any doubt, Give Kudos and accept as solution when you get one.
balkris
use attached design. The season of error is you didn't connected all the ports
Thanks and Regards
Balkrishan
amki
hi .This problem did not resolve and caused the following error.
thanks for your help
amki
I can not open this file .my simulink is R2016b
balkris
try again with attached file
Thanks and Regards
Balkrishan
amki
i want to give the inputs a matrix with 930599 elements.
how give this matrix to the in port?
i use a .mat file.
