FFT v8.0 Dynamic Reconfiguration of NFFT
I'm trying to use the XFFT core v8.0 with dynamic reconfiguration of the NFFT. From a CPU I get a config bit that should set the input sample size of the FFT to either 1024 or 2048. When this bit changes value I send a new configuration to the XFFT core changing the NFFT field. The core is generated with a maximum size of 2048 samples.
I also send a new configuration right after reset.
Results are from simulation only. Target is a Spartan 6 LX25. I'm using Isim from ISE 14.4.
Problem: The XFFT core seems to ignore a second configuration giving either a missing tlast error or simply ignores tlast and keeps expecting more data. The first configuration takes place after a reset. The second configuration takes place on CPU register write.
This is the code for dynamic reconfig:
    config_data <= CONFIG_1024 when fft_config_i = '1' else CONFIG_2048;
    config_proc : process(gclk, greset)
    begin
        if greset = '1' then
            config_val      <= '0';
            config_do       <= '0';
            config_last     <= '0';
            config_wait     <= (others => '0');
        elsif rising_edge(gclk) then
            config_val      <= '0';
            config_last     <= fft_config_i;
            if config_do = '1' and config_rdy = '1' and running = '0' then
                inc(config_wait);
                if config_wait = all_ones(config_wait'range) then
                    config_wait <= (others => '1');
                    config_val <= '1';
                end if;
                if config_val = '1' and config_rdy = '1' then
                    config_val      <= '0';
                    config_do       <= '0';
                end if;
            end if;
            if config_last /= fft_config_i or greset_n = '0' then
                config_do <= '1';
            end if;
        end if;
    end process;
fft_config_i is the CPU register output (stable for a long time). greset_n is the XFFT core reset signal (also reset on aborts). Constants are defined as:
    constant SCALING_SCHEME     : std_logic_vector(21 downto 0) := "01" & "01" & "01" & "01" & "01" & "01" &
        "01" & "01" & "01" & "01" & "10";
    constant CONFIG_1024        : std_logic_vector(31 downto 0) := '0' & SCALING_SCHEME & '0' & "000" & "01010";
    constant CONFIG_2048        : std_logic_vector(31 downto 0) := '0' & SCALING_SCHEME & '0' & "000" & "01011";
If I remove the greset_n condition from above code so I only have one configuration before first FFT calculation everything works, I will try and see if I can do a workaround setting the configuration only just before the actual FFT calculation. It just gives me worries that I cannot be sure what configuration the core is working with when there is no way to get that information from the core.
