FIR Compiler 7.2 input and output port disappears
I am using Vivado 2019.1 and system generator. The problem is when I use FIR compiler 7.2, sometime it work and most of the time when i change some option i.e. interpolation rate, coefficient vector etc, input and output port disappears.
I solved the problem, I was not entering sample period in normalized manner.
Can you please share the Matlab version as well.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
I am using Matlab version 2018a.
