03-04-2014 04:05 PM
Hi, I am new to xilinx and i created Bandstop filter using FDATool and implemented it on Spartan 6. However, I need to put input which has a monotone and noise and filter it out at the output. How can I put the input?
03-05-2014 11:09 PM
03-04-2014 05:06 PM
May be you can try band limited white noise block, please check its help for details
Vanitha
03-05-2014 05:23 AM
So sorry that I didn't mention it properly. I need input from an equipment (mix a tone with 50Hz/60Hz noise) and connect it to the fpga board to filter the noise out and then show the output in the oscilloscope.
03-05-2014 11:09 PM
