FIR IP CORE 5.0 INTERFACING OR INSTANTIATION IN USER DEFINED HDL DESIGN
Assalam u Alaikum,
I am a new user of FPGA (Verilog) IP Cores. I have to use FIR IP Core as Hilbert Transform in my project.
My question is that how do I interface the IP Core with my project. Is there required any interface code or just I have to instantiate the Core to my project, and if so how do I instantiate it in my programme file.
Re: FIR IP CORE 5.0 INTERFACING OR INSTANTIATION IN USER DEFINED HDL DESIGN
HI @kashifminhas
You will get the instantiatian template when you add the IP from the IP-catalaog.
Please look at the .vho file in the below figure. You can copy-paste in your main design to instantiate the FIR.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
