richw42a
FIR compiler gives error ERROR: [Synth 8-97] array index 2079 out of range
Using FIR compiler 7.2 (Rev. 5) with Vivado 2015.4, I get messages when I go through synthesis:
ERROR: [Synth 8-97] array index 2079 out of range [d:/local/Spheric/OptimalRanging/Artemis2/Artemis2.srcs/sources_1/ip/fir3_12/fir_compiler_v7_2_5/hdl/fir_compiler_v7_2_vh_rfs.vhd:33158]
ERROR: [Synth 8-285] failed synthesizing module 'polyphase_decimation' [d:/local/Spheric/OptimalRanging/Artemis2/Artemis2.srcs/sources_1/ip/fir3_12/fir_compiler_v7_2_5/hdl/fir_compiler_v7_2_vh_rfs.vhd:28697]
ERROR: [Synth 8-285] failed synthesizing module 'fir_compiler_v7_2_5_viv' [d:/local/Spheric/OptimalRanging/Artemis2/Artemis2.srcs/sources_1/ip/fir3_12/fir_compiler_v7_2_5/hdl/fir_compiler_v7_2_vh_rfs.vhd:59747]
ERROR: [Synth 8-285] failed synthesizing module 'fir_compiler_v7_2_5' [d:/local/Spheric/OptimalRanging/Artemis2/Artemis2.srcs/sources_1/ip/fir3_12/fir_compiler_v7_2_5/hdl/fir_compiler_v7_2.vhd:244]
ERROR: [Synth 8-285] failed synthesizing module 'fir3_12' [d:/local/Spheric/OptimalRanging/Artemis2/Artemis2.srcs/sources_1/ip/fir3_12/synth/fir3_12.vhd:76]
Since these are encrypted files, it's hard to see what's going on :(
I'll attach a couple possibly useful files.
By the way, forcing non-symmetrical coefficients removed the problem.
