connery1188
Failed to load library libPort_ExecLoader.dll because of A dynamic link library (DLL) initialization routine failed
I get this error message when I try and generate a programming file
Temporary Folder used for this compilation: C:\OPAL-RT\RT-XSG\v2.3.7.140\temp\sysgen_pw150c_simulator_FPGA
13-Jul-2018 17:44:23
fpga_model loading in progress...
fpga_model successfully loaded...
Elapsed time is 23.368525 seconds.
BoardInfo load in progress...
BoardInfo successfully loaded...
Elapsed time is 54.028221 seconds.
SysgenVersion :14.x
Removing User System Generator Block...
Elapsed time is 54.098863 seconds.
User System Generator Block removed...
Elapsed time is 54.589289 seconds.
Adding the Application Configuration Register, giving info to RT-LAB linking communication ports to application blocks...
Application Configuration Register added...
Adding System Generator Block for generation...
System Generator Block for generation added...
Elapsed time is 54.955157 seconds.
Setting parameters to System generator block...
Xilinx system Generator Block Setup:
spartan3 xc3s5000 -4 fg676
Frequency : 100 MHz
Elapsed time is 55.403895 seconds.
No duplicated IO blocks...
Failed to load library libPort_ExecLoader.dll because of A dynamic link library (DLL) initialization routine failed.
Total duration of the process :
Elapsed time is 114.859759 seconds.
C:\OPAL-RT\RT-XSG\v2.3.7.140\temp\sysgen_pw150c_simulator_FPGA\MGZ has been removed.
Configuration file generation unsuccessful.
Existing directory C:\MATLAB\R2011b\work\PW150C_SIM_FPGA\RT-XSG reports\sysgen_pw150c_simulator_FPGA\MinorID_03\ReleaseID_01 deleted
Directory C:\MATLAB\R2011b\work\PW150C_SIM_FPGA\RT-XSG reports\sysgen_pw150c_simulator_FPGA\MinorID_03\ReleaseID_01 created
I am not sure what has happened between this week and last week, but I have never seen this error before. Can anyone assist me?
I am using:
Windows 10
Xilinx ISE 14.4
Matlab R2011b
nathanx
Windows 10 is not a supported OS, see https://www.xilinx.com/support/answers/17966.html.
I do not see a specific error message in the log, is it due to long windows path?
dcole5
I'm seeing the same message.
Windows 10 / Vivado 2014.4
Everything was working last week - please fix.  My abbreviated log file is below:
Design is defaulting to srcset: sources_1
Design is defaulting to constrset: constrs_1
CRITICAL WARNING: [EDIF 20-94] Could not read core file for 'DVI_RX_FIFO' defined in file 'XXX_XXXX_XXX.edf' because ngc2edif command failed; please check the ngc2edif log at the terminal.
vavaroutsos
Really? Windows 10 came out in 2015 and Windows 7 is no longer supported. I have the same problem as everyone else here and it was working before the latest Windows 10 update. Please fix.
mmalharbi2
I have the same issue here. I am using Vivado 2015.1. Everything was perfectly working. I am using Windows 10 (Updated to the latest version). It seems that this issue appeared after the latest update of Windows 10.
Any solution?
hmleland.mms.rf
This worked for me :
"In summary: Replacing <VivadoInstallDir>/ids_lite/ISE/lib/nt64/libPortability.dll by libPortabilityNOSH.dll of the same folder resolves the problem"
asherstnev
Indeed it helped to launch Project Navigator on windows xp but then there were errors with creation of a new project and building of existing ones.
