bjoernr.
Fixed point / Floating point - <sfixed> is not declared
Hey,
in my vhdl code i need to do some fixed/floating point operations.
For example 8193 * 0.000132
Ive tried the IEEE.fixed_pkg.all; but i always get the <sfixed> or <ufixed> are not declared error.
Any suggestions how to calc with floats or fixed ?
balkris
you can use xilinx floating point operator IPs
Thanks and Regards
Balkrishan
