Frequncy Modulating a clock
I explored XIlinx IP for DDS, and am able to get 2 different frequncies (samples) based on the input clock. But what I want is to modulate the clock itself. Is there a way I can modulate (FM) a clock using DDS or otherwise? So basically the pulse width of clock will keep on varying based on the output of the FM. So if the frequncy is increasing the pulse width of clock will keep on increasing, and when the frequency  decreases the pulse width would reduce.
I will appreciate your suggestions to move in this direction.
Rgrds,
Heshsham
Tags (2)
Re: Frequncy Modulating a clock
Acatually I made a mistake in stating my question. So basically when I say I have to modulate the clock it means, the  clock duratation will  chnage based on a sine wave. So when the amplitude of sine wave increase, the clock period should increase, similarly when the amplitude of sine wave decreases,  the duration of the clcok would start decreasing and so on...
