caro@lin2a
HLS in Sysgen
I wrote a function in HLS and it worked correctly. C Simulation and Co-simulation also gave the desired answers.
My problem is, when the code is exported for sysgen, output was not correct.
The function is very simple. An array of 174 samples is fed as input and the output should be an array of 200 samples.
Output consists of two parts. First part is a preknown 26 sample array attached to the 174-sample input.
Could you please help me?
Associated files for both HLS environment(2017.4) and Matlab(R2017b) are attached.
Regards.
meherp
caro@lin2a
1. I am getting the correct results. I attached the graph and .mat file of the result.
2. I run the files which you attached in the beginning of the post.
First, I generated the sysgen-project using HLS files.
Next, imported that to Sysgen design.
3. I attached the 'init.m' file, please run the design with this init.m file (where I added zero in the beginning).
4. Can you try to rebuild the project using the original 'zip' files.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
vkanchan
I have downloaded the files that you shared to check them. Extracting them results in an error. Can you please check and share them again.
caro@lin2a
Dear vkanchan
I used winrar 5.50 (64-bit) to compress these files.
I downloaded them and check again. They were Ok.
I think, winrar with lower version may not open files compressed with this version.
I thank you very much and apologize for version miss mach.
Regards.
caro@lin2a
Dear vkanchan
In addition, files were attached non compressed for ease.
Because, number of files to attached is limited, first HLS files are sent in this post and in the next post, HLS files will be sent.
Thank you very much.
caro@lin2a
Dear vkanchan
In this post, SysGen files were attached.
vkanchan
Thank you for sharing the file. I will check them.
Vivek
meherp
caro@lin2a
1. I did not go through the logic, but following change in 'init.m' will remove the error,
% (i.e. add zeroes in the beginning)
inData              = [zeros(26, 1); Data];
2. Checked with below command and have 0 errors.
>> sum(out_Correct_mFile - outSysGen(102:301))
0
caro@lin2a
Dear meherp
Thank you very much for considering my question.
I followed your suggestions by adding zeros to data at the beginning. But unluckily, error exists. Error can be observed both by plotting as bellow
plot([out_Correct_mFile, outSysGen(102:301)])
As seen, just some first samples are the same and the rest differ.
or by typing the following command:
isequal(outFrame, outSysGen(102:301))
 which results to ‘0’ representing non equality. Using summation sounds not safe way of equality testing i guess.
 Edited version of files are attached.
Regards.
meherp
caro@lin2a
caro@lin2a
Dear meherp
Your guidance was great. I got correct answer too.
Nice point in solving the problem was pre-adding zero to data.
Failure to get correct answer was my carelessness to addition of two delay sample to the second version of .slx file.
one delay ha been added to the enable port and the other one was at the output port.
I thank you very much.
Regards.
Edited version of files were attached so that anyone interested can use.
vkanchan
HI,
To check the performance of the System Generator block generated from the HLS function, you need to pass the same test input data that you are passing the test bench in HLS. The test data input to the C function was just an array of 174 data bits and this are to be passed to the Sysgen block as well. It is not correct to manipulate the test vector by adding additional zeros before or after the data bits.
To understand how the HLS block is mapped to the System Generator block , you have to consider the mapping of input / output interface and C functions to hardware level ports and modules. In your HLS, the input and output stream functions are mapped to ap_FIFO interface in Sysgen block. That means those interfaces now accept the input data from a FIFO. The way to test the HLS block is to add a FIFO block in the sysgen design and fill in the FIFO with your test data bits. The HLS sysgen block will now read the data bits from the FIFO when the function requires it by enabling the read signal on its output interface. The function outputs Barker code bits for first 26 samples; then starts reading the test data from the FIFO and appends the data bits to output for next 174 cycles.
Please see the attached .slx file which I have created to test your HLS function. Please see the attached result which is same as your expected result.
you can check the result by command : plot([out_Correct_mFile,outSysGen(61:260)].
caro@lin2a
Dear vkanchan
I read your useful guidance and saw .slx file.
The point that there is no need to add zero at the beginning was nice.
Including FIFO to make similarity was also interesting.
But unfortunately i could not get result and the scope displayed as bellow:
i would be pleased if you could explain a little more so that i could get result out of it.
vkanchan
The reason FIFO is added there is to supply the test vector values as present in your HLS design. In the HLS design, the test vector provided to the core are Din bits(174 bits), but in here by adding zeros ahead causes the Din to be supplied with 200bits which deviates from your test case.
Ideally the array in your HLS gets mapped to FIFO interface in Hardware as the Stream interface is selected. Hence the test vectors need to be provided from a FIFO as mentioned in the HLS user guide.
Regarding the model, can you please tell me if  you are observing any error in executing the model. I have checked the model and attached the result window. Pls let me know if there is any error.
caro@lin2a
Dear
vkanchan
The reason for this is this because the step size in the step sources,connected to ap_rst and ap_start port is set 50. Please change it 50/100e6, where 100e6 is the Fs in your design. For simplicity I have changed the Fs to 1 when I tried it and hence step size  of step sources is 50. Now since Fs is different in your design, please modify the step sources by changing step size to 50/Fs.
I have checked it and it is working.
