daldoul
Hardware Co-Simulation error when downloading bit file
 I am using  System Generator to do Hardware co-cimulation for a sample example :  Addition and Multiplication,
When I Click the Start Simulation button I get an error  in the Log file :
--------------------------------- Version Log ----------------------------------
Version                                 Path
System Generator 14.2                   C:/Xilinx/14.2/ISE_DS/ISE/sysgen
Matlab 7.13.0.564 (R2011b)              C:/Program Files/MATLAB/R2011b
ISE                                     C:/Xilinx/14.2/ISE_DS/ISE
Summary of Errors:
Error 0001: Error creating a session.
     Block: 'tutorial_2_co/tutorial hwcosim'
Error 0001:
Reported by:
Details:
Error occurred during "Simulation Initialization".
I can not find the cause of error because I think I have the right version as mention in this link :
http://http://www.xilinx.com/support/answers/17966.htm
daldoul
I figured  out the problem : in the path of the  model, I have a space, so I delete this space and the Co-Simulation works fine
daldoul
Also this is my configuration for the cable:
bwiec
Are you able to configure the device using this exact hardware setup using impact? Does autodetect work?
Also, are you launching sysgen properly from the start menu/shortcut?
www.xilinx.com
daldoul
Thank you for your quick response,
I can configure the device using this exact hardware setup using impact as shown below, tow.JPG
but when i launch sysgen properly from the start menu/shortcut, I get this message on matlab : Unable to make work directory
and even so, I can find the xilinx blockset in the simulink library
daldoul
With iMPACT, I can programme the FPGA borad so I have no problem with the connexion to the borad, but I still get the error shown on my firts post with System Generator Co-Simulation.
daldoul
Maybe I didn't choose the right USB port , How can I know which port I have to select ?
daldoul
gaurav_acad
please tell me how you figured out the path problem
i aslo having the same problem as you shown in the figure
vijayenthiran
I too have the same problem !!. Where you had space? Can you expalin with the snapshot ? Will be really useful to me.
tejakr2002
there is an option for automatically detecting the cable then i think u need to mention all these
Thanks and Regards
Teja
