m3atwad
Voyager
Voyager
Help converting floating point coeff to fixed point
I'm having trouble getting started with my fir filter.  I've read around on these forums and it looks like a lot of people use the FIR compiler.  I've also read the users guide for it, but the guide doesn't contain a helpful overview for a new to DSP guy.  So the idea is...
I have a SPI module (I wrote) that is reading data from an ADC continuously.  I want to pass this data into a FIR filter as soon as the data is rx'd and after coming out of the fir LPF I save it to a register and tell the microblaze to read it.  So what I'm trying to make is a custom peripheral that consists of a SPI controller (which I already did and it works fine) and a fir filter to deliver filtered data samples to a microblaze.  The part I'm missing is how to take my FIR coefficients (this is a very basic LPF) and convert them from very small fractional floats to integers.  Below are my coefficients I got from scipy (python) which I used to generate a basic "model" of the filter.
[ -1.09615399e-18 7.96876090e-04 3.77600581e-03 1.01932394e-02
2.13824198e-02 3.79791502e-02 5.91696357e-02 8.23766260e-02
1.03640369e-01 1.18650046e-01 1.24071263e-01 1.18650046e-01
1.03640369e-01 8.23766260e-02 5.91696357e-02 3.79791502e-02
2.13824198e-02 1.01932394e-02 3.77600581e-03 7.96876090e-04
-1.09615399e-18]
As you can see, the look to be too small to apply a simple scaling factor.  What should I do?
I know Xilinx has a FIR compiler axi interface module, but implementing a second axi interface in this simple little module doesn't make any sense as it is already going to be an axi peripheral that will connect into the uBlaze.
So my ultimate questions are:
1.  What do you dsp guys generally do to convert float coefficients to fixed point or integers and what would you recommend I do?
2.  If I use the FIR compiler can I just get integer coefficients out of it and use those in my own simple fir filter module?
3.  Is there a way to implement a fir filter without having to use the axi interface?  something similar to a simple little module one could write by hand and just clock data into?
I've uploaded a simple block diagram to try to help simplify this post.  Hopefully it adds clarity to what I'm trying to develop.
Thanks!
jmcclusk
Mentor
Mentor
Here is an improved version of the filter, which uses symmetric folding and the preadders to reduce the number of DSP48's by a factor of 2.    It has zero gain at DC, and this makes it impossible to have overflow.   There is still a problem because the outside edge coefficients (0 and 20) are so small that they convert to zero.  This could be fixed.
-- Engineer: John McCluskey
-- Publish Date: 04/29/2018 7:45:00 AM
-- Design Name:
-- Module Name: filter_example - Behavioral
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.MATH_REAL.ALL;
entity filter_example is
  Port (
        clk     : in std_logic;
        in_data : in signed;
        out_data : out signed
end filter_example;
architecture Behavioral of filter_example is
constant c_width : natural := 18;  -- adjust coefficient length here.. 18 bits fits into the B input of the DSP48E1
constant c_num_coef : natural := 21;
type t_real_vector is array( natural range <>) of REAL;
type t_signed_vector is array( natural range <>) of signed(c_width-1 downto 0);
constant coeff_vector : t_real_vector(0 to c_num_coef-1) :=
( -1.09615399e-18, 7.96876090e-04, 3.77600581e-03, 1.01932394e-02,
2.13824198e-02, 3.79791502e-02, 5.91696357e-02, 8.23766260e-02,
1.03640369e-01, 1.18650046e-01, 1.24071263e-01, 1.18650046e-01,
1.03640369e-01, 8.23766260e-02, 5.91696357e-02, 3.79791502e-02,
2.13824198e-02, 1.01932394e-02, 3.77600581e-03, 7.96876090e-04,
-1.09615399e-18 );
-- this function scales the floating point coefficients so the filter has unity gain at the highest response frequency
function convert_coef( A : t_real_vector ) return t_signed_vector is
  variable B : t_signed_vector(A'range);
  variable sum_abs : real := 0.0;
begin
  for i in A'range loop  -- scale to give DC gain of unity
     sum_abs := sum_abs + abs(A(i)); -- calculate sum of absolute value
  end loop;
  sum_abs := sum_abs / real( 2**c_width - 10); -- adjust the scaling HERE  10 is for safety
    B(i) := to_signed( integer( A(i)/sum_abs ), c_width);
  end loop;
  return B;
end function convert_coef;
constant filter_coef : t_signed_vector(0 to c_num_coef-1) := convert_coef( coeff_vector );
type t_data_vector is array(natural range <>) of signed(in_data'range);
type t_preadd_vector is array(natural range <>) of signed(in_data'length downto 0);
constant c_delay : natural := c_num_coef/2;
signal pre_add : t_preadd_vector(0 to c_delay - 1) := (others => (others => '0'));
signal delay_reg : t_data_vector(0 to 2*c_delay) := (others => (others => '0'));
signal shift_reg : t_data_vector(0 to 2*c_num_coef-1) := (others => (others => '0'));
constant c_sum_len : natural := integer( log2(real(c_num_coef))) +1 + c_width + in_data'length;
type t_sum_vector is array(natural range <>) of signed(c_sum_len-1 downto 0);
signal sum_vector  : t_sum_vector(0 to c_num_coef-1) := (others => (others => '0'));
attribute use_dsp48 : string;
attribute use_dsp48 of sum_vector : signal is "yes";
begin
process(clk) is
begin
if rising_edge(clk) then
    delay_reg(0) <= in_data;
    for j in 1 to 2*c_delay loop
        delay_reg(j)     <= delay_reg(j-1);  -- this shift register should be implemented with SRL32 elements
    end loop;
    shift_reg(1) <= in_data;
    pre_add(0)   <= resize(shift_reg(1),in_data'length+1) + resize(delay_reg(2*c_delay),in_data'length+1);
    sum_vector(0) <= resize( pre_add(0) * filter_coef(0), c_sum_len);
    for i in 1 to c_delay - 1 loop
       pre_add(i)       <= resize(shift_reg(2*i+1),in_data'length+1) + resize(delay_reg(2*c_delay),in_data'length+1);
       shift_reg(2*i)   <= shift_reg(2*i-1);
       shift_reg(2*i+1) <= shift_reg(2*i);
       sum_vector(i)    <= sum_vector(i-1) + resize( pre_add(i) * filter_coef(i), c_sum_len);
    end loop;
    if c_num_coef mod 2 = 1 then
       shift_reg(2*c_delay)   <= shift_reg(2*c_delay-1);
       shift_reg(2*c_delay+1) <= shift_reg(2*c_delay);
       shift_reg(2*c_delay+2) <= shift_reg(2*c_delay+1);
       sum_vector(c_delay) <= sum_vector(c_delay-1) + resize( shift_reg(2*c_delay+2) * filter_coef(c_delay), c_sum_len);
       out_data <= resize( shift_right(sum_vector(c_delay), c_width), out_data'length);
    else
       out_data <= resize( shift_right(sum_vector(c_delay-1), c_width), out_data'length);
    end if;
end if;
end process;
end Behavioral;
m3atwad
Voyager
Voyager
Forgot to show how I actually got these coefficients:
b = signal.firwin(21, 0.01, window='blackman')
from scipy library. b is the list of coefficients.
avcon_lee
@m3atwad
I am not familiar with dsp and software, but i know that xilinx has a ip which can be used to convert floating point
numbers to fixed points. you can find [Floating-point] in IP catalog, hoping to help you
jmcclusk
Mentor
Mentor
Let me fix that for you..
-- Create Date: 04/26/2018 11:05:12 PM
-- Design Name:
library IEEE;
  Port (
        clk     : in std_logic;
        in_data : in signed(15 downto 0);
        out_data : out signed(15 downto 0)
end filter_example;
constant c_width : natural := in_data'length;  -- adjust coefficient length here.. for convenience, we make it the same as in_data
type real_vector is array( natural range <>) of REAL;
type signed_vector is array( natural range <>) of signed(c_width-1 downto 0);
constant coeff_vector : real_vector(0 to c_num_coef-1) :=
-1.09615399e-18 );
-- this function scales the floating point coefficients so the largest one is just below the peak possible
function convert_coef( A : real_vector ) return signed_vector is
  variable B : signed_vector(A'range);
  variable C : real := 0.0;  -- used for scaling
begin
  for i in A'range loop  -- first find maximum value in array
     if C < abs(A(i)) then
        C := abs(A(i));
     end if;
  end loop;
  C := C / real( 2**(c_width-1) - 1); -- adjust the scaling HERE
    B(i) := to_signed( integer( A(i)/C ), c_width);
  end loop;
  return B;
constant filter_coef : signed_vector(0 to c_num_coef-1) := convert_coef( coeff_vector );
signal shift_reg : signed_vector(0 to c_num_coef-1);
type t_product_vector is array(natural range <>) of signed(c_width+in_data'length-1 downto 0);
signal product  : t_product_vector(0 to c_num_coef -1);
attribute use_dsp48 of product : signal is "no";
signal sum_d, sum_d2, sum_d3  : signed(c_sum_len-1 downto 0);
begin
process(clk) is
 variable sum : signed(c_sum_len-1 downto 0) := (others => '0');
begin
    shift_reg(0) <= in_data;
    product(0) <= shift_reg(0) * filter_coef(0);
    for i in 1 to c_num_coef-1 loop
       shift_reg(i) <= shift_reg(i-1);
       product(i)   <= shift_reg(i) * filter_coef(i);
    end loop;
    sum := resize(product(0), c_sum_len);
    for j in 1 to c_num_coef-1 loop
       sum := sum + resize(product(j), c_sum_len);
    end loop;
    sum_d  <= sum;  -- provide some pipelining registers
    sum_d2 <= sum_d;
    sum_d3 <= sum_d2;  -- TODO...clip the output instead of truncating.
end if;
end process;
out_data <= resize( sum_d3, out_data'length);
end Behavioral;
I was quite surprised by the synthesis results..   it created 20 DSP48's, all pipelined in a row... which was not my intention, actually.   I was expecting a cloud of LUT's with an adder tree, all in fabric logic.
You might be interested by these systolic implementations of FIR filters:   https://github.com/BBN-Q/VHDL-FIR-filters/tree/master/src
After inserting this attribute:
I got the expected cloud of luts and FF's, as shown.
Oh.. and here's a testbench:
library IEEE;
library xil_defaultlib;
entity tb_filter_example is
--  Port ( );
end tb_filter_example;
architecture Behavioral of tb_filter_example is
signal clk : std_logic := '0';
signal in_data, out_data : signed(15 downto 0) := (others => '0');
signal count : unsigned(7 downto 0) := (others => '0');
begin
clk <= not clk after 5 ns;
process(clk) is
begin
  count <= count + 1;
  if count = 32 then
    in_data <= (0 => '1', others => '0');
  else
    in_data <= (others => '0');
  end if;
end if;
end process;
dut: entity xil_defaultlib.filter_example
  Port map (
        clk     => clk,
        in_data => in_data,
        out_data => out_data
end Behavioral;
Your impulse response looks like this:
QED
jmcclusk
Mentor
Mentor
So I wasn't very satisfied with the prior version,  so I  "improved" it.   Now it has coefficient scaling so that the filter can't overflow, and it uses a systolic architecture that maps very nicely into the DSP48 elements.
Voila.
-- Design Name:
-- Module Name: filter_example - Behavioral and improved systolic
library IEEE;
  Port (
        clk     : in std_logic;
        in_data : in signed(15 downto 0);  -- size can be changed, no problem
end filter_example;
-1.09615399e-18 );
begin
     sum_abs := sum_abs + abs(A(i)); -- now calculate sum of absolute value
  end loop;
  end loop;
  return B;
begin
process(clk) is
begin
    shift_reg(1) <= shift_reg(0);
    sum_vector(0) <= resize( shift_reg(0) * filter_coef(0), c_sum_len);
       sum_vector(i)      <= sum_vector(i-1) + resize( shift_reg(2*i) * filter_coef(i), c_sum_len);
    end loop;
end if;
end process;
out_data <= resize( shift_right(sum_vector(c_num_coef-1), c_width), out_data'length);
end Behavioral;
m3atwad
Voyager
Voyager
avcon_lee - Thank you for the response I actually will look into that module just out of curiousity!
Jmcclusk - Thank you very much for such an awesome response!!  I will be studying this today and attempt to understand and implement it.
Thank you both for taking the time to help me out! :)
maps-mpls
Mentor
Mentor
I use a spreadsheet or write some mcode to convert to integers.  (But I like @jmcclusk's solution too).
I don't understand this question.  You put coefficients into the FIR compiler.  You get the coefficients from some other program typically (e.g., FDATool, an Octave or python script you've written, etc.)
Yes, but the AXI interface is trivial.  See also UG901, which has Verilog/VHDL for an FIR filter.
Also, I'm not sure if you need this or not, but hopefully it will help somebody if not you:
-- S.FFF  integer  Dec. Frac.     real
--  1000       -8        -1.0   -1.000
--  1001       -7        -7/8   -0.875
--  1010       -6        -6/8   -0.750
--  1011       -5        -5/8   -0.625
--  1100       -4        -4/8   -0.500
--  1101       -3        -3/8   -0.375
--  1110       -2        -2/8   -0.250
--  1111       -1        -1/8   -0.125
--  0000        0         0      0.000
--  0001        1         1/8    0.125
--  0010        2         2/8    0.250
--  0011        3         3/8    0.375
--  0100        4         4/8    0.500
--  0101        5         5/8    0.625
--  0110        6         6/8    0.750
--  0111        7         7/8    0.875
So, a 4-bit number in 2s complement signed fractional form is trivial for positive numbers.  For negative numbers, you can just google two's complement.
*** Destination: Rapid design and development cycles ***
m3atwad
Voyager
Voyager
Thanks for the response maps!
I believe I have a much better understanding of this now after working on this today with the input I got from you guys as well as spending the day working through the source code that was so graciously posted for my benefit :)  *Thanks again jmcclusk!!
I've been working on getting the example jmcclusk posted to simulate in my verilog project as well as building a python model of it to check my verilog results - this has gone pretty well, but I have come up with another general question after not figuring it out searching the web.  Where can I find documentation for verilog that is equivalent (relative use of equivalent here as they are very different) to the numeric standards, math_real, abs() and other library as well as built in functions that were used by jmcclusk.  I am not a pro at verilog yet and was a little lost in what documents I should be following to figure these things out.  I'm just looking for reading material here to learn so this isn't a super specific question.
I understand in your first post the idea here I think in the first example jmcclusk posted:
process(clk) is
begin
    end loop;
    end loop;
    sum_d2 <= sum_d;
end if;
end process;
You are using the for loop to replicate multipliers and adders it looks like.  The multiplies look like there is a register between each multiplier creating a 1 clock delay.  The adders look like they do not - instead they are all connected "combinatorially-no register delays".  Is that correct?
The second example you posted that was a modification of the first one you said had coefficient scaling to prevent overflow.  Code below.
process(clk) is
begin
    end loop;
end if;
end process;
I'm having a hard time figuring out where the 2*i part comes from and how it helps you scale the coefficients.  Could you shed some light on what is going on here?
Next question, when you picked the amount of pipeline registers, shown below as an example,
and
did you pick them based off of what is shown in the DSP48E1 users guide where it denotes the input register delays.  Screenshot from the users guide attached as 1.jpg and 2.jpg just to show what I'm referring to.
Thanks again!!
jmcclusk
Mentor
Mentor
process(clk) is
begin
    end loop;
    end loop;
    sum_d2 <= sum_d;
end if;
end process;
Well, in this case, I was goofing around, because I wanted to see what Vivado would do with a purely behaviorial description of an FIR filter architecture.  I wanted to see how well it would collapse a bunch of constant multiplies and adders, using retiming.  The result was not great, and should be considered purely an experiment.
process(clk) is
begin
    end loop;
end if;
end process;
This had nothing at all to do with the coefficent scaling, and everything to do with the systolic "wave" filtering taken from the DSP48 User guide.  See page 51 of the DSP48 User guide, and look at Figure 3-5.   ALL these registers are already built into the DSP48 silicon, we just have to use them!
and
Again, Figure 3-5 is the crucial diagram.    I'm working now on retooling the code to handle symmetric filters, which permits reducing the number of multipliers by a factor of 2.
Important note:  There is a verilog example of the symmetric systolic FIR filter in this zip file:
https://www.xilinx.com/cgi-bin/docs/ctdoc?cid=21072360-6593-4a97-b681-a07b4e16ef37;d=ug901-vivado-synthesis-examples.zip
Grab this and take a look..   It doesn't do anything useful in terms of coefficent scaling, but it gets the filter topology right.
jmcclusk
Mentor
Mentor
-- Design Name:
library IEEE;
  Port (
        clk     : in std_logic;
end filter_example;
-1.09615399e-18 );
begin
  end loop;
  end loop;
  return B;
begin
process(clk) is
begin
    end loop;
    end loop;
    else
    end if;
end if;
end process;
end Behavioral;
