shifatbadhon
Help needed!!urgent
I am getting the following error while generating the bitstream for my project..kindly help me as i am very near to my deadline...
# Starting program map
# map -o projectnew_cw_map.ncd -intstyle xflow -detail -ol high
projectnew_cw.ngd projectnew_cw.pcf
Using target part "3s500efg320-4".
WARNING:Map:122 - The command line option -ol can only be used when running in
   timing mode (-timing option).  The option will be ignored.
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
INFO:Security:51 - The XILINXD_LICENSE_FILE environment variable is not set.
INFO:Security:53 - The LM_LICENSE_FILE environment variable is not set.
INFO:Security:54 - 'xc3s500e' is a WebPack part.
INFO:Security:68a - user is 4226267, on host A207PC22.
WARNING:Security:43 - No license file was found in the standard Xilinx license
directory.
WARNING:Security:44 - Since no license file was found,
       please run the Xilinx License Configuration Manager
       (xlcm or "Manage Xilinx Licenses")
       to assist in obtaining a license.
ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2012.01 was available
for part 'xc3s500e'.
No such feature exists.
Feature:       WebPack
License path:
H:/.Xilinx;c:\xilinx\13.4\ise_ds\ise\/data\*.lic;c:\xilinx\13.4\ise_ds\ise\/core
gen/core_licenses\Xilinx.lic;c:\xilinx\13.4\ise_ds\ise\/coregen/core_licenses\Xi
linxFree.lic;C:\Xilinx\13.4\ISE_DS\EDK/data/core_licenses\Xilinx.lic;
FLEXnet Licensing error:-5,357.  System Error: 2 ""
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".No such feature exists.
Feature:       ISE
License path:
ERROR:Map:258 - A problem was encountered attempting to get the license for this
   architecture.
Design Summary
Number of errors   :   1
Number of warnings :   1
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
Tags (2)
gszakacs
Instructor
Instructor
The error message seems to be pretty clear.  You need to run the license manager to
debug this issue.  If you have a node-locked license, make sure it matches your
host.  If you are using a floating license, you may need to set up the path to the
license server.  You might get more response on this in the Licensing and Installation
forum.
-- Gabor
