aparna
Help with the FFT block of system generator.
I would like to know how to use the FFT v6.0 in the Xilinx blockset properly as the output is always 0.
Could someone please let me know how to go about it?
The input (real) is an array of [1,0,1,0,1,0,1,0] and the imaginary part of the input is 0.
There aren't any errors as such but the output is 0.
Thank you
bwiec
You don't want to increast the latency of the block... you want to increase your simulation time to compensate for block latency.
Given the state of your control signals, I would agree with eilert that you should increase your simulation time. Or possibly, your control signals are not implemented correctly. Be sure you're referencing the datasheet for timing diagrams when interfacing to this core.
www.xilinx.com
eilert
one little hint for first time tests of FFTs:
Try feeding it with a dc-signal like : [1,1,1,1,1,1,1,1] constantly!
The result should be N*1 on the first output line, where N is the number of input samples (probably 8 in your case).
Also check the latency of the core. Maybe you just need to add some simulation time, before you can see any results coming out of the core.
Have a nice simulation
  Eilert
aparna
i will surely try it but i have a few more doubts
-Where should I increase the latency? In the FFT block is it?
-The busy flag is always 0 and valid out is also 0.So am i to assume that the output is not right?
-Does the position of binary point matter?
I did try to give a sine wave input but it still did not work as in all the output values were zeros.
I set the option as radix 2 burst I/O
Thank you so much for helping me with this :)
bwiec
www.xilinx.com
aparna
Yes increasing it worked.
thank you both sooo much :)
mrahmadi
hi
I have problems in the disposal of fft block of system generator
Please advise me
bwiec
Please create a new thread for your issue since it appears to be different.
Also, please include a description of why the core is not behaving as expected. Screenshots are helpful!
www.xilinx.com
