jwu_123
How to cascade multiplier using DSP48E
I am very new to FPGA programming and I trying to implement a 24x24 bit multiplier using the DSP48E. I have looked at several Xilinx documents, but all of them only state that multipliers larger than 25x18 can be created by cascading the DSP48. I have not found any clear procedures written anywhere on how to make a cascade multiplier.
What I understand so far: I have to cascade the DSP48E using the PCOUT and PCIN >> 17 ports. Bit select the partial products and form my final product.
Can someone give me an example of how to create a multiplier by cascading DSP48E?
Some of the documentations I have read:
https://www.xilinx.com/support/documentation/user_guides/ug193.pdf
(around page 70)
https://www.xilinx.com/support/documentation/user_guides/ug479_7Series_DSP48E1.pdf
(around page 18 )
Thank you in advance,
Jason
drjohnsmith
this might help
https://www.edaboard.com/showthread.php?276998-Combining-multipliers-to-make-larger-multiplier
basically you need to know how to do it mathamaticaly, then you can do it in the rtl.
jwu_123
Wow, I wish I knew that existed, thanks for pointing it out!
