How to import model composer inside Vitis Flow?
Hi, we are tryng to develop an image processing application starting from a matlab code,
i see model composer really is similar to matlab and i want to give it a try, maybe we need to also implement part of the alghoritm with software so we would like to accelerate with the Vitis flow.
The 2 things can be combined together?  Can i import a model composer alghorithm inside the Vitis accelerated flow?
Thanks for your post. Xilinx provides different levels of abstraction to develop the algorithm and accelerate applications on  heterogeneous platforms. Model composer provides set of library blocks to quickly connect and develop the algorithm in Simulink environment and generate a Vivado IP which can be used in downstream flows and accelerate the design using Vitis.
thank you for your reply,
so i understand they are not integrated but can be used together
