10-27-2009 07:44 AM
10-28-2009 09:19 AM
Several options for the sine wave input:
A couple of options to get the output to the DAC:
Cheers,
Jim
10-28-2009 09:19 AM
Cheers,
Jim
10-28-2009 09:45 AM
Thank you very much for helping me, jimwu.
Now i can see the sine wave in my oscilloscope.
08-05-2010 07:16 PM
Can I use this block in spartan 3An???? Or what I have to do to use the DAC and the ADC?
02-21-2011 03:21 AM
I want to do exactly the same, but it doesnt work, can you please tell me the pins that you asign and what boxes of the toolbox did you use, because I put the DSS v4.0 connected to de DAC and generate the bitstream. I am using ISE 12.1 and matlab 2010b on win 7, and FUSE probe.
Thank you
Alan
03-06-2017 12:44 PM
I am also trying to do the same thing but with a Kintex 7 board that has a FMC150 daughter card attached to it.
I was able to generate the sine wave with a DDS compiler block but I am not sure if I am sending the wave correctly for Hardware co simulation.
I created a Gateway out to send the wave to the DAC channel with the right ports but, I, still can`t see anything in the oscilloscope. Do I have to create ports for the other ports of the DAC also? Like, reset, frames, and etc?
Also, anyway to, actually, see the result in a Simulink scope instead of a oscilloscope?
