hyleung
How to parameterize IP generated by System Generator
How can I generate a parameterizable IP block to adjust the gain of CMULT when I integrate it in Vivado?  Would appreciate if you can point out any hint or solution.  Thanks
vkanchan
Hi @hyleung ,
I think this is not possible because the "CMULT" utilizes the Xilinx "Multiplier" IP in background of Sysgen. When IP/HDL netlist is triggered from Sysgen, it uses this IP and IP maps its parameter from the Sysgen GUI values to generate the output products.
