ma76571
How to store data in the rom?
I wanna store data in a rom. The document says people can set "initial value vector" of the rom like "load('filename.txt')". However, the document doesn't say how to create the filename.txt and where filename.txt should be stored. Can anybody tell me how to solve the two problems?
ma76571
Thanks for your reply. I solved my question myself.
My solution:
I used 'simout' block in simulink  to generate data to workspace first. Then, I saved the data in a noepad which was a filename.txt file. This file should be saved in 'work' file of matlab. When I set the initial value vector as 'load('filename.txt')', the data was stored in the rom. Waveform in wavescope proved my design was right.
Hi ma76571 :-)
Try out this method
-> write an m-file to generate the vector
->run the m-code once
->type the name of the variable on the workspace of matlab
->in the initial value vector space in the block properties type the name of the variable
-> now run the sysgen module and it should be fine
For eg :
I am wanting to store a vector 'vec' in the ROM whose values are = i^2 where 'i' is the index
So I write an m-code
clc;
vec = zeros(1,256)
for i=1:256
   vec(i) = i*i ;
end
run the above m-code once
then go to workspace and type 'vec'
then go to the block properties of the ROM and in the initial value vector column type 'vec'.
That should do the job.
Thank  you and regards,
Anand
now i want to store a random matrix in a rom, so can i copy the matrix into m-code ?
and i have a another question, i'll acquisiton image by a webcam and put into DRAM of FPGA kit, how can i read image and put into system generator and processing? thanks a lot
Sure you can copy the matrix into the m-code but you if you have the matrix ready you can put it on the workspace.
If you are looking to feed the image from webcam to your sysgen module for simulation then you can try the 'From video device' block in the image and video processing blocksets under 'source'
ma76571
My solution:
G7
Sir
How to store data to the notepad. Which is the 'work' file of matlab. Could you help me out
Thankyou in advance
