How to use DSP48E2 as comparator?
How do I use the DSP48E2 primitive to work as a 48-bit comparator? I couldn't find anything in the datasheet.
Tags (2)
top of head
can you subtract one from other,
and use the top bit, to detect negative or positive answer ?
top of head
