I got this error: " ERROR: latency: Value '0' is out of range '[4..25]'. Error occurred during "Rate and Type Propagation"
Hello everybody, this is the first time i post in forum.
I use divide block in xilinx toolbox in order to test 1/10. But i got this error:
Error occurred during "Rate and Type Propagation".
I try to find solution in forum but i still not found solve for my problem.
Re: I got this error: " ERROR: latency: Value '0' is out of range '[4..25]'. Error occurred during "Rate and Type Propagation"
The error message tells us how to fix this issue, we need to set the latency of divider block to a value in the range 4 to 25.
