IIR FIlter design
Sir/Madam,
                     I have made an IIR butterworth filter of order 7 the coefficients are converted to fixed point number. I have made the IIR filter by writing a verilog code as the file "baserfilter.v" and it's test benche are attached below but I am not getting the output as matlab. Then I made this system in system generator but there is an error message saying "Invalid matrix variable specified as workspace input in 'baserfilter/From Workspace'. The matrix data must be a real, double, have two dimensions, and at least two columns. The first column must contain time values and the remaining columns the data values. Matrix values cannot be Inf or NaN." I have not got proper help from my teachers please help me to find out where I am doing the error as quickly as possible .The required images are attach below .
First, display your data as signed integer in the simulation.  If it still looks bad, make sure that your calculations are not clipping or rolling over.
Try replace the FROM WORKSPACE block with the SIGNAL FROM WORKSPACE block
sir Fernando vives ,
                                     I am unable to insert the ECG signal in system generator. Whether it is "From workspace" or "signal from workspace".
