IOB pad location and IO standards in system generator
I want to make pin assignments in system generator output block for an LED on zedboard. However, there are two constraint for every pin. One is: IOB pad location and the other is: IO standards.
I would be grateful if you kindly help me make the pin assignment for LED T22 on zedboard in the output gate of system genrator.
Sara
Re: IOB pad location and IO standards in system generator
Take a look at the user guide below.
Custom boards can be created in the Vivado Design Suite as detailed in Appendix A, Board Interface File, in the Vivado Design Suite User Guide: System-Level Design Entry (UG895)
