IP Support For Little Endian
Hi all,
Is there a way to enable little endian support across the entire FPGA design?
Or, more specifically what about the complex multiply, add and FFT Vivado IP's?
I'm using Vivado 2016.4 and a Kintex 7 device.
Thanks in advance!
Teacher drjohnsmith
Re: IP Support For Little Endian
how would you convert a 32 bit number from little to big endian ?
Teacher drjohnsmith
If you have a fixed width input and output,
    as in the IP cores
       then endieness is 'just' how the bits are wired
Thanks for the reply, I see what you mean.
Any way to specify Endianness in the following register connection to LittleEndianPlease ?
reg [31:0]  LittleEndianPlease;
always @(posedge clk)
LittleEndianPlease <= 32'd16876;
Teacher drjohnsmith
