Visitor lafuan
Image processing using XSG Timing Result
Hiii
im new in DSP, and working in my final project: "comparasion in DSP for image grayscale in fpga and raspberry pi"
and my question is.... how can i see the process time from my RGB image processed to grayscale image?
i mean this exclude the pre processing and post processing after and before xilinx block
if i do the hardware cosimulation, simulink  only show the simulation which is 262144.000 which is same as my image resolution is 512*512
and what if i generate timing and power analysis from token generator? what does this generate?
Thanks for helping, you will be Appreciated
sorry for ma bad engrish
i attach the model file i use
Re: Image processing using XSG Timing Result
You can calculate the simulation run time of a model in Simulink with the MATLAB functions TIC and TOC.  The best way to do this is with a script which runs the TIC command, then simulates the model in question and then runs TOC to get the total run time.
Here is an example of an m-script that could be used assuming the model in question is called my_model.mdl:
initTime=0;            % calcuate initialization/download time by running tic / toc with a sim length of 0
                                % note that initialization only occurs the first time running a sim after opening or making changes
disp('calcuating simulation time')
tic
sim('nodefect')
TotalTime=toc
SimTime_minus_init = TotalTime - initTime
- I hope this helps!
Thanks and Regards
Balkrishan
Visitor lafuan
TotalTime and SimTime_minus_init is showing the exact same result. is that how it should be? and is the result showed is second?
try this script
close all;
clear all;
tic
nodefect
TotalTime=toc
I got this results
>> timecalc
TotalTime =
   22.0684
   22.0684
Thanks and Regards
Balkrishan
Visitor lafuan
yeah, but it should be the processing time in FPGA is much faster than the the simulink simulation? in this journal the processing time in FPGA is like 30ms. how to obtain that data?
