reenwonka_17
Image processing using XSG
Hello, i'm working on image processing using XSG..my problem is i cant display the output after the simlutaion done..the output just blank..here i attached my model and hope you can solved the problem..please help me sir
-Reen-
balkris
two issue with your design
1. Image size very small
2. You are not running simulation for enough time. Just keep in inf in simulation time.
I have modify your code and its working correctly for 256X256 image
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
reenwonka_17
Thank u so much sir..The design now working and able to displayed the output..
G7
Hi Sir
I am trying to extract RGB pixels from image and store them in Dual port RAM. But only the first value passes through the gateway. What could the problem possibly be.
My gateway in settings are
Fixed point ,unsigned ,No of bits 8 and Binary point 0
Thankyou in advance
