bhanu27
Instantiate CORDIC block in RTL
Hi All,
I am using Xilinx CORDIC IP in block diagram.
I wish to instantiate it directly in RTL rather than in block diagram.
In the IP sources, i donot see any verilog or VHDL template file.
Any ideas where I can find the instantiation template for this block
meherp
Hi @bhanu27
After instantiating the IP, you can see the template in IP resources as shown in below screenshot,
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
meherp
Hi @bhanu27
