daniel1511
Is matlab R2020a compatible with the latest xilinx system generator 2019.1?
ravidapu
Hi Daniel,
Matlab 2020a is not supported with xilinx system generator 2019.1, you can use R2018a, R2018b, R2019a versions
Raju A.
florentw
Hi @daniel1511
No. There is usually a one year latency between the vivado release and the Matlab releases because the MATLAB release needs to be out for the Model Composer to be tested before being released.
The supported matlab versions are documented in the UG976 corresponding to the vivado version you are using. This is the UG971 for 2019.1.
In table 2 you can see that MATLAB R2017a, R2017b and R2018a are supported
Florent
