JESD204B as TX
I am using JESD204B IP as a TX on KC705board, and connect kc705 with TI's DAC37J82 EVM board
My test is based on simulation result (JESD204B open IP example).
From the result of simulation, the process of sending data through GTX is
1. Register setting (same as simulation configuration)
2. tx_aresetn goes "1"              --> this signal is comming from TI EVM board
3. tx_sync goes "1"                   --> this signal is comming from TI EVM board
main handshake part is those signal
However, the big difference is
1. rising point of "tx_aresetn"
2. tx_sync doesn't go high
I understand that there are some wrong configuration on IP & DAC board setting
My concern is how to approach to the point for debug
For example,
Does "tx_sync doesn't go high " make JESD204B TX send wrong data to DAC?  so that DAC board can't send sync data to kc705 board?
or TI DAC board setting was wrong so that TI DAC board can't send tx_sync?
I just want to make sure JESD204B configuration setting is all correct.
It can be easy to debug for whole system.
I think this question should be on TI website.
But I believe that someone who is expert on this part see this question in Xilinx forum
when tx_sync goes high? (for subclass 1 operation)
it seems liek some random character (K/D/A/R/Q) goes to TI DAC37J82 EVM.
then, how it determine that it is sync or now with random character (K/D/A/R/Q).
Hope someone can answer this question too.
So, if the IP configuration setting and register setting is all same as IP example simulation,
Does it means that JESD204B setting on kc705 board doesn't have any problem?
so that I can just debug or change the configurations on TI DAC EVM board
I appreciate any comment or help
Thank you
check the example design here on tested boards
http://www.xilinx.com/member/jesd204_eval/index.htm
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
Has the page changed? I have JESD Lounge access and I don't see any reference designs - what happened?
