gyaneshwar3
JTAG Hardware cosimulation help for XC7A35T -arty board
    I have added board xml files from "https://reference.digilentinc.com/learn/software/tutorials/vivado-board-files/start", except system generator, board is able to connect and is programmble in vivado, SDK, ISE impact. After following the steps given in USER guides by xilinx, still system generator displays message "could not find JTAG device xc7a35ti",i have one more doubt regarding a file in xml {C:\Xilinx\Vivado\2017.4\data\sysgen\xml\jtagcosim_gui.xml} named as "jtagcosim_gui.xml" as shown below, should i edit them for connect it to through JTAG.
gyaneshwar3
    I have edited board.xml and part0_pin.xml files according to arty FPGA part and Hardware Co-simulation is working.
Thank you for your support
balkris
Please make sure you are using supported version of tools .
https://www.xilinx.com/support/answers/55830.html
Pleae make sure  to invoke sysgen with clicking sysgen token
You can try with modifying the design . It should be fine
Thanks and Regards
Balkrishan
gyaneshwar3
Thank you for your reply, I am using supported versions, OS: Windows 8, Matlab 2016b, vivado 2017.4
gyaneshwar3
I have tried it even in windows 10, still it is showing same message. do i have to change/ edit any .xml/.xdc files or hwcosim.xml file or any.
Thankyou in advance
gyaneshwar3
milruwan
Hello gyaneshwar3,
Currently i'm facing same problem you have faced before. I'm also using Arty A7-35T board. I have installed the Digilent board definition files and generated the JTAG Cosim block. Unfortunately I got the same error as you mentioned.
Could not find JTAG device xc7a35ti.Could not find JTAG device xc7a35ti.
Can you please specifically mention the code snippet you have modified. It would be really useful.
Thank you.
gyaneshwar3
This will work, " I have edited board.xml and part0_pin.xml files according to arty FPGA part and Hardware Co-simulation is working." change the part name to "xc7a35ti" or "xc7a35t" according to your board FPGA part name
Andrei
renaming the part in "board.xml" and "part0_pin.xml" solved nothing, more, the arty a7-35 is no longer present in the list from sysgen...
