LDPC IP Loopback problem
I want to encode one data with LDPC IP, then decode the encoded data so recover my data.
the settings of encode and decode IP are in below images.
encode:
s_axis_ctrl_tdata <= x"0f43000000";
s_axis_din_tdata <= x"251dbb6bcbd0287e5ae402cc7817d55e";
m_axis_status_tdata => "0f43006000";
m_axis_dout_tdata => "0000000000000054e1e6c2cc7817d55e";
decode:
s_axis_din_tdata <= x"0000000000000054e1e6c2cc7817d55e";
m_axis_status_tdata => "00000000";
m_axis_dout_tdata => "0000000000000000000000000000000";
as you can see i can't recover my data, Why?
I also check IP example but i can't find my mistake.
could you help me with a simple config of both decode and encode side for simple loopback.
Tags (3)
Hi @bashid ,
Column 1 of table 44 indicates LLR values obtained for demodulated data which is further quantized to format in Columm 4 of Table 44.
In your example, since modulation process is not used, each encoded bit is directly converted to 8-bit LLR data.
Convert encoded bits as follows - '0' value to -7.75 and '1' to 7.75 , represented in Fix_6_2 format and sign extended to Fix_8_2.
The decoder input needs more cycles to feed the LLR data because each encoded bit is represented as 8-bit LLR value.
Hi @bashid ,
The input data to the decoder should be LLR data and not hard encoded input. The decoder accepts 8-bit LLR input data. The requirements of input data "DIN" are mentioned on Page 55, PG281 v2.0 (Dec4,2019).
@vkanchan  Ok, but i can't understand the datasheet table.
So for loop back, i should convert each encoded 8-bits to equal llr. is it?
Is there any ip or codes that help me for this?
can tell me for example what is equal llr for x"5e".
Hi @bashid ,
Every encoded bit needs to be converted into a 8-bit LLR value for this loopback example. The IP generates C-model which has both C and MATLAB based example model that has loopback. Please refer Chapter6 in PG281, I think this should be good starting point for the loopback example.
@vkanchan  I am completely confused. I check MATLAB C model and also run it, it's map every 0's to -16 and 1's to 16. Then pass it to mex file. means, it's convert one encoded bits to 16 or -16. then pass it to LDPC.
but how it's possible! Ok, Let see what is my understanding:
we convert one bits to 5bits, so for converting 128 encoded bits to LLR, we need 128*5 = 640 bits.
is it true?
Hi @bashid ,
The LDPC MATLAB example directly converts the encoded data to LLR values as required by the LDPC IP.
This is because in real systems, LLR demodulated data is used as input to the decoder. LDPC requires 6-bit LLR data for decoder input, in format Fix_6_2 and which is sign extended to 8-bits (Fix_8_2).
LDPC IP's MATLAB example simply uses the extreme LLR values for '0' and '1' for each encoded bit and these are provided to the decoder input.
One more thing @vkanchan,
So i should convert each 5-bits (column two of table 44 in PG281) of my encoded data to corresponding 8-bit LLR data (column four of table 44 in PG281). is it?
Hi @bashid ,
