MATLAB support for 2019.1 is misleading
When I look through the 2019.1 user guide (https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug973-vivado-release-notes-install-license.pdf), table 2 mentions MATLAB 2017a, 2017b, or 2018a as the only compatible MATLAB versions. However, when I run the MATLAB Configurator for 2019.1, I find my 2017b version manually (not shown in the list by default), I get the error "MATLAB version is not supported by System Generator Vivado 2019.1".
So what versions are supported? The User Guide for 2019.1 appears to be incorrect and the https://www.xilinx.com/support/answers/55830.html page has not been updated for 2019.1 either.
Re: MATLAB support for 2019.1 is misleading
Hi @dmittiga ,
This is a typo in the document you have referrred.
Sysgen officially supports current year + last year version of Matlab.
So 2019.1 should support R2018a, R2018b and R2019a.
The documentation which you have pointed needs to be updated. Please check the below link for correct details.
https://www.xilinx.com/products/design-tools/vivado/vivado-whats-new.html#2019_1
That is why 2017b does not appear on the MATLAB configurator.
Hi @dmittiga ,
In the link you gave, It is mentioned as "Supported MATLAB Versions:R2018a, R2018b and R2019". It doesn't differentiate between R2019a and R2019b, so can you confirm is Matlab R2019b also supported by VIvado 2019.1?
sir, My system Generator 2019.2 configurator  is showing this message as you can see they no supported versions of matlab 2016a/b and 2017a/b found so is it misleading ?
You have to specify path to matlab executable file in your environment variables. Go to control panel and select environment variables and select path and add your path till matlab.exe. For example
C:\users\matlab\bin\matlab.exe
Now launch matlab configuration for the system generator and click on find matlab and select matlab installation folder.It will be configured
I have vivado 2019.1 and matlab of 2019a.
If you have still doubt then please comment again and if this solved your problem then give kudos.
